[GRASS-dev] GRASS 7 development started
Mon Apr 28 09:59:20 EDT 2008
Markus Neteler wrote:
> Today the development of GRASS 6.4 has been moved out into
> an own development branch. SVN trunk is now dedicated to GRASS 7
> development which includes major refactoring of the code and
> improvements to data formats etc.
Can we finalise the coding style, so that we can apply it?
This should be done before we start making substantial changes. Once
the code has been re-formatted, it will become much harder to compare
"before" and "after" versions, as any such diff will be dominated by
the formatting changes.
My personal preference is:
indent -bad -bap -bbb -bl -bli0 -bls -cli0 -cs -fc1 -hnl -i4 -l79 \
       -nbbo -nbc -nbfda -nbfde -ncdb -ncdw -nce -nfca -npcs -nprs \
       -npsl -nsc -nsob -saf -sai -saw -sbi0 -ss -ts8 -ut
Descriptions of the above options are given below, although it may be
more clear to just apply the above command to a bunch of files and
look at them.
Others will presumably have different preferences; in which case
please express them sooner rather than later.
The precise style doesn't really matter[1]; what DOES matter is that
we have one style for all of GRASS, and that everyone abides by it[2].
[1] Except for -ts8, which isn't a stylistic choice but a file format
issue. Using something other than -ts8 is irrational; the only other
sane alternative is to just forbid tabs outright (-nut, --no-tabs).
This is particularly important for Python code, where indentation is
syntatic, not just stylistic. I would suggest using "python -t -t ..."
to catch this.
[2] The main advantage of 7.x is the ability to make incompatible API
changes. Any such changes will typically require changing files across
large numbers of modules. Expecting developers to modify their text
editor's formatting settings from one file to the next (because
different files have different formatting) is unacceptable, IMHO.
Descriptions of the above options:
       -bad, --blank-lines-after-declarations
           Force blank lines after the declarations.
       -bap, --blank-lines-after-procedures
           Force blank lines after procedure bodies.
       -bbb, --blank-lines-before-block-comments
           Force blank lines before block comments.
       -bl, --braces-after-if-line
           Put braces on line after if, etc.
       -blin, --brace-indentn
           Indent braces n spaces.
       -bls, --braces-after-struct-decl-line
           Put braces on the line after struct declaration lines.
       -clin, --case-indentationn
           Case label indent of n spaces.
       -cs, --space-after-cast
           Put a space after a cast operator.
       -fc1, --format-first-column-comments
           Format comments in the first column.
       -hnl, --honour-newlines
           Prefer  to  break  long  lines  at  the position of newlines in the
           input.
       -in, --indent-leveln
           Set indentation level to n spaces.
       -ln, --line-lengthn
           Set maximum line length for non-comment lines to n.
       -nbbo, --break-after-boolean-operator
           Do not prefer to break long lines before boolean operators.
       -nbc, --no-blank-lines-after-commas
           Do not force newlines after commas in declarations.
       -nbfda, --dont-break-function-decl-args
           Don't  put  each  argument  in a function declaration on a seperate
           line.
       -nbfde, --dont-break-function-decl-args
           Break the line after the last argument in a declaration.
       -ncdb, --no-comment-delimiters-on-blank-lines
           Do not put comment delimiters on blank lines.
       -ncdw, --dont-cuddle-do-while
           Do not cuddle } and the while of a do {} while;.
       -nce, --dont-cuddle-else
           Do not cuddle } and else.
       -nfca, --dont-format-comments
           Do not format any comments.
       -npcs, --no-space-after-function-call-names
           Do not put space after the function in function calls.
       -nprs, --no-space-after-parentheses
           Do not put a space after every '(' and before every ')'.
       -npsl, --dont-break-procedure-type
           Put the type of a procedure on the same line as its name.
       -nsc, --dont-star-comments
           Do not put the `*' character at the left of comments.
       -nsob, --leave-optional-blank-lines
           Do not swallow optional blank lines.
       -saf, --space-after-for
           Put a space after each for.
       -sai, --space-after-if
           Put a space after each if.
       -saw, --space-after-while
           Put a space after each while.
       -sbin, --struct-brace-indentationn
           Indent braces of a struct, union or enum N spaces.
       -ss, --space-special-semicolon
           On one-line for and while statments, force a blank before the semi-
           colon.
       -tsn, --tab-sizen
           Set tab size to n spaces.
       -ut, --use-tabs
           Use tabs. This is the default.
