[GRASS-dev] c code: access region/window yllcorner and xllcorner
values
Glynn Clements
glynn at gclements.plus.com
Tue Apr 29 11:59:42 EDT 2008
Yann Chemin wrote:
> I am trying make a module to (among other things) export a flow
> direction map in a specific ascii format.
> I need to access the region or window xllcorner and yllcorner, right now,
> the only code I found was to access cellhd.xxx variables:
> xmin=cellhd.west;
> xmax=cellhd.east;
> ymin=cellhd.south;
> ymax=cellhd.north;
> which is not exactly my need since the xllcorner and yllcorner are
> going to be part of the header of the new ascii file, where pixels
> will be extracted from within the region limits.
struct Cell_head cellhd;
G_get_window(&cellhd);
xllcorner=cellhd.west;
yllcorner=cellhd.south;
