[GRASS-dev] v.digit linking error on osx
William Kyngesburye
woklist at kyngchaos.com
Tue Apr 29 16:44:07 EDT 2008
The current wxpython vdigit makefile is incompatible with OSX. There
hasn't been a decision yet how to handle it.
Here is a vdigit makefile I sent to Michael that works:
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080429/7d1da373/Makefile.obj
On Apr 29, 2008, at 3:29 PM, Colin Rundel wrote:
> I'm attempting to compile a svn snapshot on my macbook and I'm
> running into a roadblock with getting v.digit to compile. I've
> followed the instructions in the wxpython readme and created the
> symlink to _gdi_.so from wxpython but I get the following error:
> cc -dynamiclib -compatibility_version 6.4 -current_version 6.4 -
> install_name /usr/local/grass-6.4.svn/lib/libgrass6_wxvdigit.dylib -
> o OBJ.i686-apple-darwin9.2.2/_grass6_wxvdigit.dylib -L/Users/rundel/
> Desktop/grass/grass6_devel/dist.i686-apple-darwin9.2.2/lib
> OBJ.i686-apple-darwin9.2.2/cats.o OBJ.i686-apple-darwin9.2.2/digit.o
> OBJ.i686-apple-darwin9.2.2/driver.o OBJ.i686-apple-darwin9.2.2/
> grass6_wxvdigit_wrap.o OBJ.i686-apple-darwin9.2.2/line.o OBJ.i686-
> apple-darwin9.2.2/select.o OBJ.i686-apple-darwin9.2.2/undo.o
> OBJ.i686-apple-darwin9.2.2/vertex.o -lgrass_vect -lgrass_dbmibase -
> lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient -
> lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -
> lgrass_datetime -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -
> lgrass_datetime -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -
> lz -lgrass_linkm -lgrass_rtree -lgrass_dig2 -lgrass_gis -
> lgrass_datetime -lz -lgrass_rtree -lgrass_dgl -lgrass_rtree -
> lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -
> lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -
> lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -L/Library/
> Frameworks/GDAL.framework/Versions/1.5/unix/lib -lgdal -lgrass_gis -
> lgrass_datetime -lz -L/Library/Frameworks/GDAL.framework/
> Versions/1.5/unix/lib -lgdal -lgrass_vedit -lgrass_gis -
> lgrass_datetime -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -
> lgrass_datetime -lz -lgrass_dbmiclient -lgrass_dbmibase -
> lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -
> lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -
> lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lz -
> lgrass_linkm -lgrass_rtree -L/usr/local/lib -framework IOKit -
> framework Carbon -framework Cocoa -framework System -framework
> QuickTime -lwx_macu_richtext-2.8 -lwx_macu_aui-2.8 -
> lwx_macu_xrc-2.8 -lwx_macu_qa-2.8 -lwx_macu_html-2.8 -
> lwx_macu_adv-2.8 -lwx_macu_core-2.8 -lwx_base_carbonu_xml-2.8 -
> lwx_base_carbonu_net-2.8 -lwx_base_carbonu-2.8 -L/Library/
> Frameworks/Python.framework/Versions/2.5/lib/python2.5/config -ldl -
> lpython2.5 -lgdi
> ld: in /usr/local/lib/libgdi.so, can't link with bundle (MH_BUNDLE)
> only dylibs (MH_DYLIB)
> collect2: ld returned 1 exit status
> make: *** [OBJ.i686-apple-darwin9.2.2/_grass6_wxvdigit.dylib] Error 1
> This seems to have something to do with how I've compiled wxpython
> on my system, but playing with the obvious build flags for wxpython
> has had no effect ( I've tried both the current stable release and
> svn).
> Just as a philosophical aside, I havent had much time to explore the
> wxpython code yet, but what was the compelling reason for the use of
> the PseudoDC in the first place? Does the C++ driver provide a
> significant speed up or is it something else that I am missing?
> Thanks,
> -Colin
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
