[GRASS-dev] Re: [GRASS GIS] #241: v.proj: broken (?) -z description and missing -l description in wxGUI
GRASS GIS trac at osgeo.org
Fri Aug 1 06:08:14 EDT 2008
  Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  reopened
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Changes (by msieczka):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Replying to [comment:1 martinl]:
 >   -z   3D vector maps only
 >         Assume z co-ordinate is ellipsoidal height and transform if
 possible
 > That's right "3D vector maps only" is short flag description and "Assume
 z co-ordinate is
 > ellipsoidal height and transform if possible" is extended description,
 The 2 descriptions should be the other way round I think - "3D vector maps
 only" alone does not explain much. It would do as extra info (tooltip), if
 "Assume z co-ordinate is ellipsoidal height and transform if possible" was
 the main description. Is it possible to swap them?
Ticket URL: <http://trac.osgeo.org/grass/ticket/241#comment:2>
