[GRASS-dev] Re: [GRASS GIS] #241: v.proj: broken (?) -z description
and missing -l description in wxGUI
trac at osgeo.org
Fri Aug 1 07:47:06 EDT 2008
#241: v.proj: broken (?) -z description and missing -l description in wxGUI
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by martinl):
Replying to [comment:2 msieczka]:
> Replying to [comment:1 martinl]:
> > That's right "3D vector maps only" is short flag description and
"Assume z co-ordinate is
> > ellipsoidal height and transform if possible" is extended description,
> The 2 descriptions should be the other way round I think - "3D vector
maps only" alone does not explain much. It would do as extra info
(tooltip), if "Assume z co-ordinate is ellipsoidal height and transform if
possible" was the main description. Is it possible to swap them?
Done, r32442 and r32445.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/241#comment:3>
