[GRASS-dev] Re: Code re-indentation: done.
Markus Neteler
neteler at osgeo.org
Wed Aug 6 06:27:02 EDT 2008
On Tue, Aug 5, 2008 at 9:11 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> I have discovered that we overlooked
>> lib/external/*
>> to be taken out from reformatting.
>> Is there an easy way to revert a set of files to their respective
>> previous versions?
>> svn revert only works with unsubmitted changes.
>> Didn't find any other useful reference...
> find lib/external -type f -name '*.[ch]' | \
> while read file ; do
> svn merge -c -32526 $file
> done
> Here, 32526 is the revision corresponding to the indenting of the
> trunk. Passing a negative revision to "svn merge -c" will "unmerge"
> that change.
It didn't work like this:
[neteler at markus grass70]$ find lib/external -type f -name '*.[ch]' | \
> done
svn: REPORT request failed on '/grass/!svn/vcc/default'
svn: Cannot replace a directory from within
AFAIK because https://svn.osgeo.org/grass/grass/trunk is lacking.
I tried some other ways to yet no avail.
Markus
