[GRASS-dev] Re: Code re-indentation: done.
Markus Neteler
neteler at osgeo.org
Mon Aug 11 07:19:09 EDT 2008
On Tue, Aug 5, 2008 at 11:17 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Martin Landa wrote:
>> btw what to do with messages indented like
>> G_message(_
> Damn; I thought that not specifying -l would prevent this from
> happening.
>> manually fix when fixing/updating code to?
>> G_message(_(...));
> We can fix them automatically:
> find . -type f -name '*.c' | xargs grep -l '(_$' | \
> while read file ; do sed -i -e '/(_$/{;N;s/\n[ \t]*//;}' $file ; done
> [Note: using \t in a character set is a GNU extension; other versions
> of sed need a literal tab character.]
I have added this gettext polishing trick to
tools/grass_indent.sh
Using this script you can format easily the file indentation to the new standard
before submitting to SVN.
Markus
