[GRASS-dev] Re: [GRASS GIS] #229: v.random: add random sampling
from vector points map
trac at osgeo.org
Mon Aug 11 08:54:09 EDT 2008
#229: v.random: add random sampling from vector points map
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: vector
Platform: All | Cpu: All
Comment (by neteler):
The idea to use separately v.random and v.what.vect fails as it introduces
new data points:
v.info -c lidar1map
g.region vect=lidar1map
v.random output=random_samples10 n=3800 --o
v.db.addtable map=random_samples10 columns='cat integer, height double
precision'
v.what.vect vector=random_samples10 column=height qvector=lidar1map
qcolumn=N3 dmax=100
while it should subset existing data points.
Suggestion: maybe better use v.extract and add a "random=" parameter there
which populates internally the "list=" list of categories?
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/229#comment:1>
