[GRASS-dev] grass7: rename some G_OPTs in parser.c
Mon Aug 11 20:14:41 EDT 2008
Markus Neteler wrote:
> >> > I would suggest to rename DB related G_OPTs in parser.c to
> >> > G_OPT_DB_, e.g. G_OPT_WHERE to G_OPT_DB_WHERE.
> +1
> >> > Since those defines were added recently, maybe could be possible to
> >> > rename them also in grass6 (or to define aliases) ?
> > no aliases cluttering things up please, lets just do the job right, once.
> > AFAIK we only guarantee the user interface is stable within grass 6.x, not the library interface.
> Are these G_OPTs externally used (GDAL, SWIG..)?
> If not, let's do it also in (devbr6).
You might also consider back-porting r31628, which checks that the
module was built with the same version of gis.h as libgis.
