[GRASS-dev] testing d.thematic.area - problem
Moritz Lennert mlennert at club.worldonline.be
Tue Aug 12 16:44:25 EDT 2008
On 12/08/08 22:14, Michael Barton wrote:
> On Aug 12, 2008, at 11:03 AM, Markus Neteler wrote:
>> Michael,
>> On Tue, Aug 12, 2008 at 6:58 PM, Michael Barton
>> <michael.barton at asu.edu> wrote:
>>> Moritz,
>>> I just tried out d.thematic.area from develbranch_6 (updated from svn
>>> last
>>> night).
>>> It compiled without error, but failed on running with the following
>>> message:
>>> dyld: lazy symbol binding failed: Symbol not found: _G_gisinit
>>>  Referenced from:
>>> /Applications/Grass/GRASS-6.4.app/Contents/MacOS/bin/d.thematic.area
>>>  Expected in:
>>> /Applications/Grass/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gis.dylib
>>> dyld: Symbol not found: _G_gisinit
>>>  Referenced from:
>>>  Expected in:
>> the G_gisinit symbol thing was introduced the other day (backport, to
>> ensure that compatible GIS libraries are used).
>> Perhaps you have an old libgis hanging around somewhere?
>> "make distclean" is needed, too.
> I've updated from the svn develbranch_6,
> installed the new d.thematic.area files by doing a tar -xvf thematic.tar
> did a make distclean, and make.
> None of d.thematic.area compiled.
> I checked and none of the pieces were in the Make files any more, so I
> added them back in.
> They still won't compile.
You need to compile lib/arraystats before you can compile
display/d.thematic.area.
Moritz
