[GRASS-dev] standarizing range syntax
Glynn Clements
glynn at gclements.plus.com
Wed Aug 13 01:29:14 EDT 2008
Michael Barton wrote:
> Currently, due to its history, GRASS has various ways of designating a
> range of values.
> In raster displays (d.rast) ranges are expressed as 'n-n';
> for color tables, they are implied but not explicitly given;
> for raster reclass maps (r.reclass), they are expressed as 'n thru n'
> for raster recode (r.recode), they are expressed as 'n:n';
> for vector reclass (actually a recode, v.reclass), ranges are
> expressed in SQL syntax
> At least for rasters, I'd like to suggest that we standardize range
> notation.
> I recommend 'n-n'. It is compact, widely recognized, and doesn't use a
> misspelled english word ("thru"). The syntax 'n:n' is used in some
> programming, but not a lot beyond that.
One issue with "m-n" is that it could be quite easy to inadvertently
write code which doesn't handle negative values correctly, e.g.
"-10--5". IMHO, it's also less clear than "-10:-5".
