[GRASS-dev] iostream lib and r.terraflow/r.viewshed
Paul Kelly paul-grass at stjohnspoint.co.uk
Thu Aug 14 08:59:38 EDT 2008
On Thu, 14 Aug 2008, Glynn Clements wrote:
> Do it. If a C++ header uses strcpy(), it *should* be including
> <cstring>. What happens thereafter is a separate issue.
Done now for ami_stream.h (thanks Martin) and mem_stream.h in both trunk
and develbranch_6.
Paul
