[GRASS-dev] Re: [GRASS GIS] #254: wxpython Layer Manager: higher raster hides the lower
GRASS GIS trac at osgeo.org
Thu Aug 14 14:16:30 EDT 2008
  Reporter:  giohappy  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:  fixed     |    Keywords:
  Platform:  Linux     |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:3 martinl]:
 > I am not quite sure if '--o' should be defaut for d.rast as it is in
 TCL/TK GUI.
 I think so. There doesn't seem to be much point in having layers if you
 only get to see the topmost one.
 Also, consider using a patterned background (as per GIMP, PhotoShop etc),
 so that it's easier to distinguish the background from the layer (e.g. to
 eliminate "setting the null-value colour doesn't work" reports). The
 contrast should be a lot lower than for GIMP etc, though. Maybe
 95%-grey/white, just enough to be visible.
Ticket URL: <http://trac.osgeo.org/grass/ticket/254#comment:4>
