[GRASS-dev] Re: [GRASS GIS] #254: wxpython Layer Manager: higher
raster hides the lower (GRASS GIS)
Glynn Clements
glynn at gclements.plus.com
Fri Aug 15 11:12:46 EDT 2008
Martin Landa wrote:
> >> BTW, when I start g.gui without arguments the dialog is launched
> >> instead of the GUI. This behaviour is not right I guess, the 'gui'
> >> parameter has already defined default value. Now you are forced to run
> >> `g.gui gui=wxpython`.
> > That's becasue the gui= option is marked as required:
> > type = G_define_option();
> > type->key = "gui";
> > type->required = YES;
> > even though it always has a default value:
> > gui_type_env = G__getenv("GRASS_GUI");
> > if (gui_type_env && strcmp(gui_type_env, "text")) {
> > type->answer = G_store(gui_type_env);
> > else {
> > type->answer = "tcltk";
> > If you remove the ->required setting, the dialog shouldn't appear.
> well, I think the 'gui' parameter should stay required. Maybe I am
> missing something, but what is wrong on the required parameter with
> defined default value?
You are misunderstanding the meaning of the ->required field.
The ->required field indicates that the option must be provided *by
the program's arguments*. Given that any value which is provided by
the program's arguments will override any default value, there is no
point in both setting the ->required field and providing a default
value, as the ->required setting ensures that the default will always
be overriden.
> > In r32756, I removed all of the "argc > 1" hacks, and always call
> > G_parser(). It only generates the dialog if no arguments are given and
> > there is at least one required option.
> I see, I think also default value(s) should be checked here, i.e.
> don't generate the dialog if there is required option with defined
> default value?
See above.
