[GRASS-dev] syntax for v.db.update???
Michael Barton michael.barton at asu.edu
Fri Aug 15 13:31:24 EDT 2008
I've tried this all combinations that I can think of and still get an
error. So I'm asking the larger community if anyone knows the secret
handshake is to get v.db.update to put RGB values into a column for
coloring vectors.
I would like to get the following to work.
v.db.update map=fields layer=1 column=area value=0:128:128
where=area>=101 and area<=10000
I've tried delimiting with no quotes, double quotes, single quotes,
and curly braces. Nothing seems to work. See below. Any suggestions?
GRASS 6.4.svn (Spearfish60_test):~ > v.db.update map=fields layer=1
column=area value="0:128:128" where="area>=101 and area<=10000"
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected $undefined, expecting $end
or ';' processing ':'
in statement:
UPDATE fields SET area=0:128:128 WHERE area>=101 and area<=10000
Error in db_execute_immediate()
ERROR: Error while executing: 'UPDATE fields SET area=0:128:128 WHERE
column=area value='0:128:128' where='area>=101 and area<=10000'
in statement:
column=area value={0:128:128} where={area>=101 and area<=10000}
bash: =10000}: No such file or directory
column=area value={0:128:128} where=area>=101 and area<=10000
bash: =10000: No such file or directory
column=area value={0:128:128} where="area>=101 and area<=10000"
dbmi: Protocol error
ERROR: Error while executing: 'UPDATE fields SET area={0:128:128} WHERE
column=area value={0:128:128} where='area>=101 and area<=10000'
Michael
