[GRASS-dev] syntax for v.db.update???
Martin Landa
landa.martin at gmail.com
Fri Aug 15 14:25:50 EDT 2008
2008/8/15 Michael Barton <michael.barton at asu.edu>:
>> this should work
>> v.db.update map=fields layer=1 column=value value='0:128:128'
>> where="area>=101 and area<=10000"
>> Martin
> Unfortunately not.
> GRASS 6.4.svn (Spearfish60_test):~ > v.db.update map=fields layer=1
> column=area value='0:128:128' where="area>=101 and area<=10000"
are you sure that you want to update column 'area'...
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
