[GRASS-dev] Re: [GRASS GIS] #163: g.transform no longer calculating error for 2nd order transformation
GRASS GIS trac at osgeo.org
Sat Aug 16 13:21:30 EDT 2008
  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  closed
  Priority:  major     |   Milestone:  6.4.0
 Component:  default   |     Version:  svn-develbranch6
Resolution:  fixed     |    Keywords:  g.transform georectify
  Platform:  All       |         Cpu:  Unspecified
Changes (by cmbarton):
  * status:  new => closed
 * cc: glynn at gclements.plus.com (added)
  * platform:  => All
  * milestone:  6.3.1 => 6.4.0
  * resolution:  => fixed
  * cpu:  => Unspecified
Comment:
 It turns out that 2nd order transformation need MORE than 6 points, not 6
 points or more--at least in g.transform. There needs to be a change to the
 help file  about this (for g.transform if different from i.rectify, or for
 i.rectify if in both). I've changed the information in the interactive
 georectify modules for TclTk and wxPython. I'm closing this because it is
 not really a bug (or at least I don't think so), but some misinformation
 in the docs.
Ticket URL: <http://trac.osgeo.org/grass/ticket/163#comment:2>
