[GRASS-dev] grass7 make install errors
Andrew Danner adanner at cs.swarthmore.edu
Sun Aug 17 10:43:10 EDT 2008
I'm getting some make install errors in grass7 on ubuntu x64
If I don't run with --with-nls, I get the following error. Can the makefile
be modified to skip this step if nls is disabled (default)
cd /home/adanner/packages/grass7/dist.x86_64-unknown-linux-gnu ; tar cBf -
locale | (cd /usr/local/stow/grass7-svnAug2008//grass-7.0.svn ; tar xBf - )
2>/dev/null
tar: locale: Cannot stat: No such file or directory
tar: Error exit delayed from previous errors
I haven't been able to eliminate this error:
sed
's#'/home/adanner/packages/grass7/dist.x86_64-unknown-linux-gnu'#'/usr/local/stow/grass7-svnAug2008//grass-7.0.svn'#g'
/home/adanner/packages/grass7/dist.x86_64-unknown-linux-gnu/etc/monitorcap >
/usr/local/stow/grass7-svnAug2008//grass-7.0.svn/etc/monitorcap
sed: can't read
/home/adanner/packages/grass7/dist.x86_64-unknown-linux-gnu/etc/monitorcap:
make[1]: [real-install] Error 2 (ignored)
Neither of these seem critical, but should I have a monitorcap? I have a
monitorcap in the grass6_devel build, but no locale, though 6.4 doesn't seem
to look for a locale directory by default
svn info
Revision: 32838
cat my_grass70_configure
#CXXFLAGS='-g -O2 -D_LARGE_FILE_SOURCE -D_FILE_OFFSET_BITS=64' \
#CFLAGS='-g -O2 -D_LARGE_FILE_SOURCE -D_FILE_OFFSET_BITS=64' \
./configure --prefix=/usr/local/stow/grass7-svnAug2008/ \
--without-postgres --with-cxx --enable-largefile \
--with-tcltk-includes=/usr/include/tcl8.4 \
--with-python=/usr/bin/python2.5-config \
--with-proj-share=/usr/share/proj \
--with-freetype \
--with-cairo \
--enable-64bit \
--with-wxwidgets=/usr/bin/wx-config \
--with-sqlite
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080817/f3c20eaa/attachment.html
