[GRASS-dev] Re: [GRASS GIS] #163: g.transform no longer calculating
error for 2nd order transformation
trac at osgeo.org
Sun Aug 17 10:44:19 EDT 2008
#163: g.transform no longer calculating error for 2nd order transformation
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords: g.transform georectify
Platform: All | Cpu: Unspecified
Changes (by hamish):
* status: closed => reopened
* resolution: fixed =>
Comment:
> It turns out that 2nd order transformation need MORE than 6 points, not
6 points
> or more
Not according to the i.rectify man page,
"The number of control points required for a selected order of
transformation (represented by n) is ((n + 1) * (n + 2) / 2) or 3, 6, and
10 respectively."
And imagery/i.vpoints/analyze.c's compute_transformation() which leads to
imagery/i.vpoints/crs.c's calccoef() function agrees. n >= 6.
The same code is reused by g.transform, I assume they are identical after
re-indent.
no idea about what the needs of backtransforming are. I assume they are
symetric with a forward transform.
No idea if any of this matters to the status this bug. Reopening as the
reason for closing it is invalid and the interactive georectify modules
now need to be reverted.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/163#comment:3>
