[GRASS-dev] some questions about future development
Glynn Clements
glynn at gclements.plus.com
Wed Aug 20 10:03:22 EDT 2008
Glynn Clements wrote:
> Known issues at present:
> Null support is missing (r.external records any null value reported by
> GDAL, but G_get_raster_row() etc ignore it; I suspect that it will
> treat zero as null due to the absence of a null file).
Null support has been added.
> The code which retrieves the range tells GDAL that approximate values
> will suffice (requiring exact values requires reading the entire map,
> in which case you may as well just use r.in.gdal).
r.external now has a -r flag to tell GDAL to compute the exact range
rather than an approximation.
