[GRASS-dev] Re: [GRASS GIS] #263: wxgui: v.in.ascii's SQL column defintion text box is uneditable
GRASS GIS trac at osgeo.org
Wed Aug 20 15:35:16 EDT 2008
  Reporter:  epatton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  minor    |   Milestone:  6.4.0
 Component:  wxGUI    |     Version:  svn-develbranch6
Resolution:           |    Keywords:  v.in.ascii, SQL, columns
  Platform:  Linux    |         Cpu:  x86-64
Comment (by epatton):
 The following errors were printed to the terminal when I was using the
 v.in.ascii wxpython gui:
   File "/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/menuform.py",
 line 1377, in OnDbColumn
     p = self.task.get_param('layer')
 line 202, in get_param
     raise ValueError, _("Parameter not found: %s") % aParam
 ValueError: Parameter not found: layer
 ~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/263#comment:1>
