r.external - was: Re: [GRASS-dev] some questions about future development
Thu Aug 21 09:44:05 EDT 2008
Markus Neteler wrote:
> >> >> Null support is missing (r.external records any null value reported by
> >> >> GDAL, but G_get_raster_row() etc ignore it; I suspect that it will
> >> >> treat zero as null due to the absence of a null file).
> >> > Null support has been added.
> >> I have now tested (in my local 6.4 backport) a shaded terrain map (GeoTIFF).
> >> The 0 pixels are registered as NULL pixels, leading to white areas instead
> >> of black in case of cast terrain shadow.
> >> So I confirm that zero is treated as NULL now.
> >> Could the GDAL Null value be used instead?
> > Null support was added in r32924, and seems to work.
> Ha - I missed to backport this one.
> Excellent, it now works fine in my local backport, too.
> So: any objections to submit this new feature/module?
Is it really wise to include it in 6.4?
At a minimum, we should probably add some more checks so that versions
built without this feature fail more gracefully (i.e. produce a more
useful error message).
