[GRASS-dev] Vlib: how to delete an object from a GRASS vector map
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Thu Aug 21 12:54:01 EDT 2008
Dear all,
I am struggling to understand how to delete an object, including its
attached attributes, from a GRASS vector map.
I open the map with:
Vect_open_update ( &Map, MAPS[i].tempname, mapset );
Then I find the category IDs of the objects I want to delete and then I
do:
Vect_delete_line ( &Map, cat );
Vect_field_cat_del ( Cats, field, cat );
and Vect_close() after the work is done.
However, the next module I try to run on the modified map
throws an error:
ERROR: Attempt to read dead line [282]
How do I eliminate dead lines from the map?
Thanks,
Ben
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeology Ltd
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
