[GRASS-dev] GDAL ticket 2537: lib/gis/range.c and lib/gis/find_file.c issues
Sun Aug 24 16:06:31 EDT 2008
Markus Neteler wrote:
> Please take a look at
> http://trac.osgeo.org/gdal/ticket/2537
Someone else needs to be reminded that the solution to memory leaks in
GRASS libraries is not to use those libraries from persistent
applications. The GRASS libraries exist for GRASS, and are designed
for GRASS; whether or not they are useful for anything else isn't
really an issue.
OTOH, I've committed a fix for the descriptor leak in
lib/proj/datum.c; that actually matters.
