[GRASS-dev] Re: [GRASS-SVN] r33046 - in grass/trunk/lib: cairodriver pngdriver
Maciej Sieczka tutey at o2.pl
Mon Aug 25 10:56:06 EDT 2008
svn_grass at osgeo.org pisze:
> Author: glynn
> Date: 2008-08-23 22:20:30 -0400 (Sat, 23 Aug 2008)
> New Revision: 33046
> Modified:
>    grass/trunk/lib/cairodriver/Graph.c
>    grass/trunk/lib/pngdriver/Draw_line.c
>    grass/trunk/lib/pngdriver/Polygon.c
> Log:
> Fix bug with cairo driver failing to erase background
> Fix bug with PNG driver skipping topmost line of polygon
> Change PNG driver's line-drawing to use FP throughout
 From the changes as above, is the "Fix bug with PNG driver skipping
topmost line of polygon" appropriate for backporting?
Maciek
Maciej Sieczka
www.sieczka.org
