[GRASS-dev] get_row.c: output north/east values? G__.window
structure
Markus Neteler
neteler at osgeo.org
Tue Aug 26 11:08:03 EDT 2008
On Tue, Aug 26, 2008 at 3:10 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> I try to understand an issue mentioned on grass-user but get only enigmatic
>> error messages:
>> v.extrude -t bldg_cmcl out=bldg_cmcl_3d height=15
>> elev=el_D792_6m --o
>> WARNING: Vector map <bldg_cmcl_3d> already exists and will be overwritten
>> WARNING: Reading raster map <el_D792_6m at PERMANENT> request for row 220803
>> is outside region
>> ERROR: Problem reading raster map
> Any warning generated there is useless to the end user, as it
> indicates a bug in the code. It's the caller's responsibility to avoid
> requesting rows which lie outside the current region.
> I've committed fixes to a number of bugs in G_get_raster_sample().
> Apart from trying to read invalid rows, it was deliberately reading
> the wrong rows at the edge of the region, and pretending that nulls
> were zero (they aren't; just because you would like a definite (i.e.
> non-null) answer, that doesn't mean that you can have one).
I have backported this.
> I've also fixed v.sample to deal with the fact that the result may be
> null.
> v.extrude and v.drape also use that function, so they may need similar
> changes.
Does below makes sense for v.extrude?
[neteler at markus v.extrude]$ svn diff
Index: main.c
--- main.c (revision 33093)
+++ main.c (working copy)
@@ -405,6 +405,9 @@
voffset_curr = G_get_raster_sample(fdrast, &window, NULL,
Points->y[k], Points->x[k], 0,
NEAREST);
+ if (G_is_d_null_value(&voffset_curr))
+ continue;
if (k == 0) {
voffset_dem = voffset_curr;
@@ -425,11 +428,16 @@
NEAREST);
+ continue;
if (type != GV_POINT) {
voffset_next = G_get_raster_sample(fdrast, &window, NULL,
Points->y[k + 1],
Points->x[k + 1], 0,
NEAREST);
+ continue;
Full example - NC dataset (http://www.grassbook.org/data_menu3rd.php):
g.region rural_1m -p
# P079215 is in PERMANENT
# extract buildings, based on original DXF data set
v.extract P079215 out=bldg_resid where="layer='BLDG_RESID_BL'"
# add height of the building
v.extrude -t bldg_resid out=bldg_resid_3d height=10 \
elev=el_D792_6m
# this should show 3D blocks (and did so until recently!):
nviz el_D792_6m vect=bldg_resid_3d
Loading raster map <el_D792_6m at PERMANENT>...
99%
Translating colors from raster map <el_D792_6m>...
Vector map <bldg_resid_3d at neteler> loaded (4 features)
There are only 2D polygons shown :(
Also: why only 4 features?
v.info -t bldg_resid_3d
nodes=14
points=0
lines=11
boundaries=0
centroids=0
areas=0
islands=0
faces=0
kernels=0
primitives=11
map3d=1
I would expect faces here. Looking at this:
v.out.ascii bldg_resid_3d format=standard
ORGANIZATION:
DIGIT DATE:
DIGIT NAME: neteler
MAP NAME:
MAP DATE: Tue Aug 26 17:02:03 2008
MAP SCALE: 1
OTHER INFO: Generated by v.extrude from vector map <bldg_resid at PERMANENT>
ZONE: 0
MAP THRESH: 0.000000
VERTI:
L 9 1
638745.93649987 220589.98018792 138.74661255
638761.33502667 220593.60121917 138.92004395
638760.72542545 220596.16154429 138.92004395
638764.00508001 220596.94183385 138.9642334
638760.90830582 220610.07264411 138.90388489
638750.36220472 220607.59766316 139.04286194
638751.27660655 220603.70840738 139.04286194
638743.14452629 220601.78206753 139.05780029
1 49
L 5 1
638773.49047498 220587.26136649 138.49179077
638776.68478537 220587.38328673 138.49179077
638776.75793752 220585.12776222 138.28727722
638773.56362713 220585.00584198 138.49179077
1 50
suggests that no longer faces are written by v.extrude.
Despite the new NVIZ/whatever bug, is above patch ok?
Markus
