[GRASS-dev] r.spread compilation problem
Tue Aug 26 16:53:17 EDT 2008
Yann Chemin wrote:
> OBJ.x86_64-unknown-linux-gnu/display.o: In function `display_init':
> /home/yann/tmp/grass/raster/wildfire/r.spread/display.c:39: undefined
> reference to `D_get_screen_window'
> /home/yann/tmp/grass/raster/wildfire/r.spread/display.c:108: undefined
> reference to `D_reset_screen_window'
> /home/yann/tmp/grass/raster/wildfire/r.spread/display.c:135: undefined
> collect2: ld returned 1 exit status
> make: *** [/home/yann/tmp/grass/dist.x86_64-unknown-linux-gnu/bin/r.spread]
> Error 1
> root at siduxbox:/home/yann/tmp/grass/raster/wildfire/r.spread#
r.spread is known to be broken.
I'm not sure how to handle animation (if at all) in the absence of
XDRIVER (animation with direct rendering is largely pointless, as
you'll only see the last frame).
For now, I'll just disable the -d option, so that it's a normal r.*
module (rather than a hybrid r.*/d.* module).
