[GRASS-dev] Re: r.external
Glynn Clements
glynn at gclements.plus.com
Wed Aug 27 09:20:55 EDT 2008
Markus Neteler wrote:
> I found a problem with FP maps:
> gdalinfo /tmp/geodata2_originals_raid5/pat_DTM_5m_derived_LIDAR_UTM_WGS84/pat_DTM_2008_derived_5m_UTM_WGS84.tif
> Band 1 Block=23522x1 Type=Float32, ColorInterp=Gray
> File size (if that matters): 2458610122
> GRASS 7.0.svn (patUTM):~/grass70 > r.external
> in=/tmp/geodata2_originals_raid5/pat_DTM_5m_derived_LIDAR_UTM_WGS84/pat_DTM_2008_derived_5m_UTM_WGS84.tif
> out=pat_dtm_5m
> Projection of input dataset and current location appear to match
> <pat_dtm_5m> created
> r.external complete.
> GRASS 7.0.svn (patUTM):~/grass70 > d.rast pat_dtm_5m
> PNG: GRASS_TRUECOLOR status: FALSE
> PNG: collecting to file: map.png,
> GRASS_WIDTH=640, GRASS_HEIGHT=480
> WARNING: Unable to find
> '/home/neteler/grassdata/patUTM/neteler/cell_misc/pat_dtm_5m/f_format'
Try r33119.
I didn't set the lzw_compression_bits field; AFAICT, nothing uses it
(even for normal maps).
Is the f_quant file also necessary?
