[GRASS-dev] Re: [GRASS-user] weird dbf file in GRASS 6.4
maning sambale
emmanuel.sambale at gmail.com
Fri Aug 29 06:34:58 EDT 2008
Maciek,
> You used the '-v' switch which means: "Use raster values as categories
> instead of unique sequence". Thus, it is normal that the output table
> has only that many rows, as many unique cell values were there in the
> input raster map. Multiple polygons are linked to the same table row (by
> having the same category), so there are more polygons than rows in the
> table indeed.
This make sense, thank you for clearing this out. I created a new
vector without the -v switch and it looks ok now.
cheers,
maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
