[GRASS-dev] r.in.xyz: really big ints
Helena Mitasova
hmitaso at unity.ncsu.edu
Fri Aug 29 09:15:29 EDT 2008
On Aug 29, 2008, at 3:19 AM, Hamish wrote:
> Hi,
> a user has just successfully imported a 92GB LIDAR data file with
> r.in.xyz
> (2.4 billion data points; 4.5hrs). This has exposed a cosmetic bug,
> the
> number of points processed is reported to the user as -1871174186.
> The raster output is fine AFAIK, but the broken status message ain't a
> good look.
> wc -l reports 2,424,200,605 points which is bigger than (IIUC) the
> 32bit
> limit for c90 int of 2,147,483,648. I do not know if the hardware/
> OS/build
> was 32 or 64 bit. The "line" variable is defined simply as "int".
It was a 64 bit with GRASS6.4 compiled from 8/22/08 version
Doug, you could add more details and maybe also post your comparison
of GRASS performance on linux versus MS Windows,
Helena
> Apparently `wc` on their system can count higher than 2^31, can we?
> Is it as simple as replacing printf %d with %u ?? (seems to work)
> In that case should the variable be defined as "unsigned int" for
> correctness? (%u seems to work correctly with plain signed int in a
> little test program I wrote) Then we wait for the first 160GB
> dataset...
> I could rewrite it to store the number of lines as a double and printf
> %.0f, but hope for a cleaner solution.
> side idea:
> Would it be possible to add a flag to g.version to report some build
> info? Like: 32/64 bits, endianness, build date, svn checkout date (if
> applicable), `uname -a` of build machine, LFS, nls, and in general
> ./configure feature report stuff, ...
having that would be greatly appreciated
> thanks,
> Hamish
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
