[GRASS-dev] Re: [GRASS GIS] #163: g.transform no longer calculating
error for 2nd order transformation
trac at osgeo.org
Sat Aug 30 12:57:03 EDT 2008
#163: g.transform no longer calculating error for 2nd order transformation
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords: g.transform georectify
Platform: All | Cpu: Unspecified
Comment (by msieczka):
Replying to [comment:5 hamish]:
> Replying to [comment:4 cmbarton]:
> > Well, when I use exactly 6 GCP's the RMS values returned by
g.transform are 0,
> IIUC that is RMS *error* value is 0, not results. By specifying the
minumum number of points have you just fit a perfect surface to the
points, and so no error? or is the actual fit bad?
On GDAL API reference pages [1] it reads that "Note that 2nd order
requires at least 6 GCPs, and 3rd order requires at least 10 gcps". GDAL
uses the same algorithm as GRASS and this info is coherent with GRASS
manual.
AFAIK, for any transformation supported by i.rectify, adding an extra
point above the minimum lets the algorithm calculate residuals. If only
the very required number of points is provided, the transformation result
is still valid, but you don't know the RMS. Given that, g.transform should
return 0 with 6 values, but i.rectify should work. If it doesn't it's
strange.
[1]http://www.gdal.org/gdal__alg_8h.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/163#comment:6>
