[GRASS-dev] build without NLS broken
Glynn Clements
glynn at gclements.plus.com
Tue Dec 2 05:15:29 EST 2008
Markus Neteler wrote:
> >> In r34485 there were a bunch of changes to lib/gis/gisinit.c, one of
> >> which calls G_init_locale(). However, this is not necessarily defined
> >> in locale.c. I'm not really a C guy, but this seemed to fix it for
> >> me. For reference, the build fails on an undefined reference to
> >> G_init_locale. I tried it on an Ubuntu machine and on OS X.
> > Oops.
> > I have changed lib/gis/locale.c (r34662) so that only the code which
> > depends upon libintl.h is conditionalised, but G_init_locale() is
> > defined unconditionally. This ensures that the setlocale() calls still
> > occur, which is necessary to ensure that e.g. printf("%f") isn't
> > localised.
> Does this affect 6?
r34662 fixes a bug in r34485, so r34662 should only be back-ported if
r34485 was back-ported (I presume it wasn't).
