[GRASS-dev] testing results of r.watershed2 against old
r.watershed
Hamish
hamish_b at yahoo.com
Wed Dec 3 00:34:38 EST 2008
Markus Metz:
> > The new version of r.watershed produces results identical to the
> > original version at a substantial speed increase by optimizing the A *
> > search method.
that reminds me, the man page needs updating too,
"Both versions use the AT least-cost search algorithm to determine the flow of water over the landscape (see SEE ALSO section). The algorithm produces results similar to those obtained when running r.cost and r.drain on every cell on the map." [...]
thanks,
Hamish
