[GRASS-dev] Re: [GRASS GIS] #72: PNG driver: boundary rendering is off by one pixel
GRASS GIS trac at osgeo.org
Wed Dec 3 03:54:26 EST 2008
  Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  blocker      |   Milestone:  6.4.0
 Component:  default      |     Version:  svn-develbranch6
Resolution:               |    Keywords:  d.vect, rendering, PNG_DRIVER
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:10 hamish]:
 echo "symbol geology/strike_triangle 22 50 50 black black" >
 draw_triangle.dgr
 d.graph draw_triangle.dgr
 Okay. There were two problems with the existing polygon filler, which
 should be fixed by attachment:ticket:72:pngdriver-polygon.patch.
 The first is that the x coordinates were calculated for the top of the
 pixel rather than the centre, causing an effective downward shift.
 The second is that the x coordinates were truncated rather than rounded,
 causing a leftward shift.
 In the test case, both of these contribute to the gap on the right-hand
 side, while the latter contributes to the overlap on the left-hand side.
 The one issue which this patch doesn't attempt to address is the fact that
 all lines are effectively shifted half a pixel down and to the right. This
 is inherent in the use of integer coordinates. While you can draw a
 polygon with orthogonal edges perfectly aligned to the pixel grid, you
 can't draw a single-pixel orthogonal stroke with its centre-line so
 aligned.
 I have attached PNG files containing the output before and after the
 patch, as well as corresponding SVG files which show exactly what is
 happening in more detail. The actual vertices passed to the rendering
 functions (both line and polygon) are [(315,240), (320,229), (325,240)].
 This corresponds to the black triangle. The red triangle shows the half
 pixel down-right shift inherent in the line drawing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/72#comment:11>
