[GRASS-dev] Re: [GRASS GIS] #72: PNG driver: boundary rendering is
off by one pixel
trac at osgeo.org
Wed Dec 3 06:21:16 EST 2008
#72: PNG driver: boundary rendering is off by one pixel
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords: d.vect, rendering, PNG_DRIVER
Platform: Unspecified | Cpu: Unspecified
Comment (by glynn):
Replying to [comment:12 hamish]:
> thanks a lot for looking into this- to me this issue is a really bad
look for us, sloppy output makes the project look sloppy. (and annoying
for me to have to use xwd instead of d.out.file in 6.4.
If you want quality, I would expect both the cairo and PS drivers to
produce better results overall than either PNG or XDRIVER. However, you
might run into corner cases where code relies upon the half pixel down-
right shift, which isn't present in those drivers. You might also run into
problems with the distinction between polylines and multiple line segments
(caps versus joins) being visible.
Ticket URL: <https://trac.osgeo.org/grass/ticket/72#comment:13>
