[GRASS-dev] Re: [GRASS GIS] #355: ps.map generates invalid
postscript when vlegend item does not appear on map
trac at osgeo.org
Fri Dec 5 04:43:56 EST 2008
#355: ps.map generates invalid postscript when vlegend item does not appear on
map
Reporter: scottygamm | Owner: hamish
Type: defect | Status: closed
Priority: minor | Milestone: 6.4.0
Component: ps.map | Version: 6.3.0
Resolution: fixed | Keywords:
Platform: MSWindows CygWin | Cpu: x86-32
Changes (by hamish):
* status: assigned => closed
* cc: casey.vandenberg at sjgeophysics.com, bcovill at tekmap.ns.ca (added)
* resolution: => fixed
Comment:
patch applied in SVN, thanks!
I also fixed the vector legend bug reported by Casey Vandenberg on Nov 20
where it wouldn't let you place the vector legend to the left of the map
box. Now you can go as far as the left margin. The right side of the
legend (for multicolumn) is still rather unconstrained, I've left it as
not starting a new column past the right side of the map box, which seems
like a fair compromise. Feel free to post a patch doing that better if you
can figure out how.. I don't think it is easily possible to improve on the
current way.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/355#comment:5>
