[GRASS-dev] r.watershed2 with MFD
Helena Mitasova hmitaso at unity.ncsu.edu
Fri Dec 5 15:38:01 EST 2008
Markus,
at this point, as you suggest, the best would be to work on this in
grass7 - do you have SVN commit access?
Helena
On Dec 5, 2008, at 3:02 PM, Markus Metz wrote:
> Dylan Beaudette wrote:
>> On Fri, Dec 5, 2008 at 1:55 AM, Markus Metz <markus_metz at gmx.de>
>> wrote:
>>> I took the request for MFD support in r.watershed by Helena and
>>> Dylan to
>>> heart and implemented it, but still need a few more days to clean
>>> up the
>>> code, then I want to submit it as r.watershed2.mfd to grass-addons.
>> Is there any way to
>> cleanly merge this with the existing r.watershed code in SVN so that
>> we can test it?
> Also considering Michael's remarks, I suggets that I then not submit
> to
> grass-addons, but to grass 7. Not to grass-6.4.x, because this code is
> now more experimental and documentation still needs to be written.
> The MFD algorithm seems to be robust and produces the expected results
> with nice differences according to the convergence factor, but the
> other
> outputs are different and I don't know yet if this is ok and desired
> or not.
> The basins and half-basins are different, less so for coarser
> resolution, rather disastrous with MFD for the 1m LIDAR DEM in the
> North
> Carolina dataset. It seems that such a DEM should be processed with
> coarser resolution to obtain basins and half-basins that make sense,
> apparently both for SFD and MFD, but these a just first impressions.
You may be using a threshold that is too small.
> Slope length (LS for USLE) and slope steepness (S for USLE) are about
> 99.9% identical between SFD and MFD with the DEM <elevation> in the
> North Carolina dataset. Streams are again different, i.e. MFD streams
> need to be thinned then they are very similar to SFD, but MFD streams
> make sense.
> Once I have added MFD to segmented mode too and updated the
> documentation, the module is ready to be submitted and scrutinised by
> others.
> This is no easy feat to modify r.watershed, I want to make sure the
> old
> behaviour is preserved when adding new functionality and I need some
> more time before submitting. I don't like to submit code with bugs...
> Markus Metz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
