[GRASS-dev] [GRASS GIS] #392: backport G_is_c_null_value() to devbr6
trac at osgeo.org
Sun Dec 7 08:41:44 EST 2008
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: task | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
I'm a bit overwhelmed at work right now, and Markus is busy too, so filing
this as a task for 6.4 so that it doesn't get forgotten, & 'll get to it
when I do.
Glynn wrote:
However, I suggest syncing G_is_c_null_value() (and possibly other
parts of null_val.c) to 7.0.
Doing this with "svn merge" isn't practical as some of the changes
were part of large-scale clean-ups (r34445, r34484).
The original code is over-complex as a result of trying to handle
arbitrary sizes for CELL, FCELL and DCELL. But I suspect that a lot
more than just null handling would break if those types weren't 4, 4
and 8 bytes respectively.
If you want to sync the whole file, you'll also need to sync the
prototypes in gisdefs.h, as some gratuitous "int" returns were changed
to "void". I don't think that anything actually checked the return
types, so it shouldn't be necessary to change anything else (unlike
e.g. G_get_window(), where many modules checked the return value even
though it would always be 1).
Ticket URL: <https://trac.osgeo.org/grass/ticket/392>
