[GRASS-dev] [GRASS GIS] #395: wxGUI: can't handle whole-Earth extent
GRASS GIS trac at osgeo.org
Wed Dec 10 17:27:52 EST 2008
 Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  6.4.0
Component:  wxGUI     |     Version:  svn-develbranch6
 Keywords:            |    Platform:  All
      Cpu:  All       |
 In lat/long locations GRASS GUI can't handle extent greater than 180W-
 180E:90S-90N.
 Example:
 $ g.region res=1 n=90 s=-90 w=-180 e=180 rows=180 -g
 n=90
 s=-90
 w=-180
 e=180
 nsres=1
 ewres=1
 rows=180
 cols=360
 cells=64800
 $ v.in.region out=check
 $ g.gui wxpython&
 Add the vector map 'check' to display, try to pan or zoom out - error:
 Execution failed: 'd.vect map=check at PERMANENT
 type=point,area,face,centroid,line,boundary --q'
 Details:
 Error: region for current mapset line 4: <north: 468.670220741>run
 "g.region"
 The Map Window brakes. You need to restart it. This makes browsing global
 lat/long data very problematic. Issue present in gis.m as well.
Ticket URL: <http://trac.osgeo.org/grass/ticket/395>
