[GRASS-dev] v.build: why is attaching islands taking so long?
Hamish
hamish_b at yahoo.com
Thu Dec 11 01:34:48 EST 2008
> Hamish pisze:
> "Florida coastline" problem
Maciej wrote:
> Skiming through GDAL 1.6 announce I noticed the following:
> "Add a segmentize() method to OGRGeometry to modify the geometry such it
> has no segment longer then the given distance; add a -segmentize option
> to ogr2ogr"
> Relevant?
perhaps, but distance would need to by by number of vertices, not map
distance - as maps can be of many scales and there is no single "max
distance". (I guess you could calculate map bounds and use 5% of max
side..) And you'd need a GDAL version check to stay backwards compatible
with older GDALs for the next 2-3 years or so. (extended Debian life cycle)
but I wonder, would a simple, but large, box of 4 vertices (corners) which
surrounds a complicated vector map (many islands) still take so long to
build? in that case, reducing the number of sequential vertices wouldn't
help.
probably need to run some trials with v.in.region + v.patch to test that.
Hamish
