[GRASS-dev] compile error with vdigit nviz
    Martin Landa
    landa.martin at gmail.com
    Thu Dec 11 15:02:12 EST 2008
2008/12/11 Jamie Adams <jaadfoo at gmail.com>:
> Ok, that helped.  Now I'm only getting an error with vdigit
>>>cd /usr/local/work/build/grass6_devel/gui/wxpython/vdigit
>>>make
> /usr/bin/ld: cannot find -lgdi
> collect2: ld returned 1 exit status
> make: *** [OBJ.x86_64-unknown-linux-gnu/_grass6_wxvdigit.so] Error 1
from
http://svn.osgeo.org/grass/grass/trunk/gui/wxpython/README
First, create a symlink to _gdi_.so shared library
$ sudo ln -s `locate _gdi_.so` /usr/local/lib/libgdi.so
e.g.
$ sudo ln -s /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so
Then update LD_LIBRARY_PATH or add '/usr/local/lib' to /etc/ld.so.conf
(in this case run 'sudo ldconfig').
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
