[GRASS-dev] Re: [GRASS GIS] #305: Add created map into layer tree: errors for import modules
GRASS GIS trac at osgeo.org
Fri Dec 12 10:37:37 EST 2008
  Reporter:  msieczka  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Changes (by martinl):
  * status:  new => assigned
  * owner:  grass-dev at lists.osgeo.org => martinl
 * cc: grass-dev at lists.osgeo.org (added)
Comment:
 Replying to [ticket:305 msieczka]:
 > 1. in preferences set "Add created map into layer tree"
 > 2. try to import using any module, in GUI, = errors
 should be fixed in r34836 (6.4), r34837 (7.0).
 > Moreover, re-running the command with ovewrite will add the layer again
 (so after 2 re-runs you have the layer twice on the list, and so forth).
 Could this be avoided?
 You can always disable adding new layer into layer tree if you re-run the
 same command...
Ticket URL: <http://trac.osgeo.org/grass/ticket/305#comment:2>
