[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not work
GRASS GIS trac at osgeo.org
Tue Dec 16 04:49:42 EST 2008
  Reporter:  helena       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  critical     |   Milestone:  6.4.0
 Component:  Raster       |     Version:  svn-trunk
Resolution:               |    Keywords:  r.out.gdal, tiff
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by mmetz):
 The attached patch r.out.gdal.rangecheck.patch would add a check whether
 the user specified nodata value is within the range of the selected GDAL
 datatype and whether the selected GDAL datatype covers the range of each
 input raster band. The default nodata value is now set to the minimum of
 the selected GDAL datatype for all datatypes. Writing out an all black
 colortable in case that no colortable could be read is disabled. BTW, it
 seems that some changes in the patch are there because the original code
 was not indented with grass_indent.sh.
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/73#comment:27>
