[GRASS-dev] Re: [GRASS GIS] #402: v.in.ogr buffer overflow
trac at osgeo.org
Tue Dec 16 09:10:29 EST 2008
Reporter: epatton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Resolution: | Keywords: buffer overflow, vector, shapefile, import
Platform: Linux | Cpu: x86-64
Comment (by epatton):
It seems the problem is larger than just importing this shapefile. I tried
exporting a different Grass vector from a different location to shapefile
using v.out.ogr, then importing that shapefile back into its parent
location. I get the same result, a buffer overflow.
Can anyone with a 64-bit system test importing shapefiles with v.in.ogr?
~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/402#comment:4>
