[GRASS-dev] Re: [GRASS GIS] #344: TODO: move high priority incubated modules into main
GRASS GIS trac at osgeo.org
Wed Dec 17 16:08:38 EST 2008
  Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
      Type:  task     |      Status:  new
  Priority:  blocker  |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-develbranch6
Resolution:           |    Keywords:
  Platform:  All      |         Cpu:  All
Comment (by mlennert):
 Replying to [comment:14 martinl]:
 > Replying to [comment:13 hamish]:
 > > remaining TODO for this ticket:
 > >  - v.out.ascii.db -> v.out.ascii C code
 > done in r34917. Please test it out...
 In trunk, I get the following error during compile:
 VERSION_NUMBER=7.0.svn
 /home/mlennert/SRC/GRASS/grass_trunk/tools/g.html2man/g.html2man.py
 /home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-
 gnu/docs/html/v.out.ascii.html /home/mlennert/SRC/GRASS/grass_trunk/dist.
 i486-pc-linux-gnu/man/man1/v.out.ascii.1
 gnu/docs/html/v.out.ascii.html:90:0: Error ({'args': ()}): <o>
 make: *** [/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-
 gnu/man/man1/v.out.ascii.1] Erreur 1
 rm v.out.ascii.tmp.html
 In devel6, I can compile, but I get a segmentation fault using NC demo
 data and running:
 v.out.ascii in=hospitals out=hospitals.ascii colu=NAME
 but not with
 v.out.ascii in=hospitals out=hospitals.ascii colu=PHONE
 GRASS 6.4.svn (nc_spm_06):~ > v.info -c hospitals
 Displaying column types/names for database connection of layer 1:
 INTEGER|cat
 INTEGER|OBJECTID
 DOUBLE PRECISION|AREA
 DOUBLE PRECISION|PERIMETER
 INTEGER|HLS_
 INTEGER|HLS_ID
 CHARACTER|NAME
 CHARACTER|ADDRESS
 CHARACTER|CITY
 CHARACTER|ZIP
 CHARACTER|COUNTY
 CHARACTER|PHONE
 CHARACTER|CANCER
 INTEGER|POLYGONID
 DOUBLE PRECISION|SCALE
 DOUBLE PRECISION|ANGLE
 GRASS 6.4.svn (nc_spm_06):~ > v.db.connect -p hospitals
 Vector map <hospitals at PERMANENT> is connected by:
 layer <1> table <hospitals> in database
 </home/mlennert/GRASS/DATA/nc_spm_06/PERMANENT/dbf/> through driver <dbf>
 with key <cat>
 Running
 for col in `v.info -c hospitals | awk -F"|" '{print $2}'`; do echo $col;
 v.out.ascii in=hospitals out=hospitals_$col colu=$col; done
 gives segfaults with NAME and ADDRESS and "Illegal instruction" with CITY.
 The same script on comm_colleges causes seg faults for the columns
 ADDRESS1 and "Illegal instruction" on CC_NAME and ADDRESS2.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/344#comment:15>
