[GRASS-dev] Re: [GRASS GIS] #344: TODO: move high priority incubated modules into main
GRASS GIS trac at osgeo.org
Wed Dec 17 21:07:57 EST 2008
  Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
      Type:  task     |      Status:  new
  Priority:  blocker  |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-develbranch6
Resolution:           |    Keywords:
  Platform:  All      |         Cpu:  All
Comment (by hamish):
 Martin:
 > done in r34917. Please test it out...
 great!
 It works for me; I don't get any segfaults.
 I notice that the column names are case sensitive; and could the column
 check be moved before any output? and the error message should be like
 "column <%s> not found" ?
 GRASS64> v.out.ascii in=hospitals col=name,phone
 ERROR: Column <name>: unsupported data type
 697237.5638615|182012.65540056|1GRASS64>
 cheers,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:17>
