[GRASS-dev] NVIZ problem on Mac
William Kyngesburye
woklist at kyngchaos.com
Sat Dec 20 00:34:40 EST 2008
No crashes for me. Both from CLI and GUI.
A few odd bits:
- it starts with the controls panel collapsed, though the expand/
collapse widget says it's expanded. And when I click it once it stays
collapsed, though the widget changes, click again and it finally
expands.
- There is also an error every time I do this:
unknown option "-label"
while executing
"$Nv_(AREA).menu.config.m entryconfigure 1 -label "Show Panels" -
command "show_menus""
(procedure "hide_menus" line 9)
invoked from within
"hide_menus"
invoked from within
".middle.panelarea.f1.b1 invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke]"
(procedure "tk::ButtonUp" line 23)
invoked from within
"tk::ButtonUp .middle.panelarea.f1.b1"
(command bound to event)
- The tooltips defocus the NVIZ window, which is slightly annoying in
most cases, but for popup menus (ie Decorations...) unpops the menu.
Even if I'm fast enough to select a menu item, the tooltip popup still
happens and the selection is ignored.
The tooltips don't affect the sliders (another GUI widget where you
hold the mouse button on it for a period of time), but I wonder if
that's because Tk Aqua doesn't use OSX sliders. Popup menus do use
OSX menus.
On Dec 19, 2008, at 5:31 PM, Michael Barton wrote:
> I don't know what the source of this is, but in the current 6.4
> build of GRASS (last week's SVN) NVIZ doesn't seem to work under Mac
> OS X. It crashes when you try to start it in any mode. As usual,
> there is not much info about an NVIZ crash.
> This is with the TclTk 8.5 aqua version. We may have to revert to
> x11 for Mac.
> Michael
> ______________________________
> C. Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole. Now what
does that remind me of? Ah, yes - life."
- Marvin
