[GRASS-dev] question about error in r.watershed
Sat Dec 20 23:06:10 EST 2008
Michael Barton wrote:
> > The fix would be to add the following lines in front/main.c at line
> > 223
> >   /* LS factor and basin.thresh */
> >   err += (opt14->answer != NULL && opt6->answer == NULL);
> I applied your patch and got the following compiler error:
> r.watershed/front >> /Users/cmbarton/grass_dev/grass6_src/error.log
> gcc -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.6.0/
> include  -arch i386 -Os       -DPACKAGE=\""grassmods"\"  -I/Users/
> cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.6.0/include -o
> OBJ.i386-apple-darwin9.6.0/main.o -c main.c
> main.c: In function �main�:
> main.c:224: error: stray �\202� in program
Presumably, that's in the line you added.
I suspect an error in the copy/paste from the email. I've attached
Markus' suggested change as a binary attachment.
Type: application/octet-stream
Desc: r.watershed patch
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20081221/0274ef19/r.watershed.obj
