[GRASS-dev] [GRASS GIS] #407: Can not set vector layer properties
GRASS GIS trac at osgeo.org
Sun Dec 21 03:15:36 EST 2008
 Reporter:  jachym  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect  |      Status:  new
 Priority:  major   |   Milestone:  6.4.0
Component:  wxGUI   |     Version:  svn-develbranch6
 Keywords:          |    Platform:  Linux
      Cpu:  x86-32  |
 When I want to add new vector layer to map display, it appears in the GIS
 Manager window, but none window pops up, where I could choose new layers
 name (and mapset) (d.vect window, I guess). For rasters, this works. The
 new vector layer is called "vector map (doubleclick to change
 properties)".
 The problem appears ONLY, when LANG set to something different from "C" (I
 use cs_CZ.UTF8 - I did not tested other languages). When LANG=C and g.gui
 gui=wxpython&, everything works like  a charm.
 Tested with new 6.4. branch.
Ticket URL: <http://trac.osgeo.org/grass/ticket/407>
