[GRASS-dev] Re: [GRASS GIS] #305: Add created map into layer tree:
errors for import modules
trac at osgeo.org
Sun Dec 21 13:14:27 EST 2008
#305: Add created map into layer tree: errors for import modules
Reporter: msieczka | Owner: martinl
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: fixed | Keywords:
Platform: All | Cpu: All
Changes (by martinl):
* status: assigned => closed
* resolution: => fixed
Comment:
Replying to [comment:2 martinl]:
> > Moreover, re-running the command with ovewrite will add the layer
again (so after 2 re-runs you have the layer twice on the list, and so
forth). Could this be avoided?
> You can always disable adding new layer into layer tree if you re-run
the same command...
It's feature, closing the ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/305#comment:3>
